Set whether the screen saver is enabled, as well as the screen saver delay action time, screen saver brightness, and normal display brightness. When the screen enters the screen saver, the first tap on the touch screen will not trigger the action, but simply revert to the normal display state; Using the illuminated brightness register, you can also set the default power-on brightness of the serial screen. Please refer to the user manual for details.
https://www.stoneitech.com/support/download
Reply To: How do I set the screensaver and how do I adjust the brightness?Fiona Liu2020-12-17T17:51:36+08:00
