Hello ikarcuaso
The real-time curve displays a y value instead of an X value.
In your example:
The smallest unit in the X direction is 0.1.That means you need to create a coordinate with X units of 0, 1.
In our software, you can set the horizontal interval to the minimum distance between X units, from 1 to 255(pixels).
This means that you can enter and display a Y value between each X pixel. This curve is constant, you need to input every Y value for this curve, and then you get the complete curve in coordinates.
This is a basic concept. So, if you can follow the instructions and get a curve showing the demo, it will be easier to operate.
